Anyone with an Easy cam replacement Method?
Old Oct 13, 2005 | 01:59 PM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Anyone have an easy cam replacement method without tearing half of your car apart?
Old Oct 13, 2005 | 03:48 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Pull accessores, pull intake, pull radiator. The cam will actualy come out, without taking the engine out, or the front end. There is just enough room to slide it out, so long as the radiator and AC stuff is out of the nose.
Old Oct 13, 2005 | 04:34 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
YOu will have to pull the radiator but you don't have to remove the a/c condenser. If you unscrew all of it's brackets it will rotate out of the way. That will save you from recharging the system.
Old Oct 13, 2005 | 07:57 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There are two ways of changing a cam. With the motor in the car or with the motor out of the car. There aren't any steps that you can skip. Refer to the LT1 cam digest for specific "how to" instructions. You will find the proper way, along with hints, of installing a cam into your 305 TBI.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
BurlyChev
Aug 16, 2015 09:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
