is this tbi unit good??
Old Oct 13, 2005 | 06:47 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
i just bought a tbi unit for a spare from a member here and was unaware but someone has tried to perform the ultimate tbi mods on it and didnt do a good job imo...it isnt grounded even where they took the ridge off some parts are ground just a hair lower than the normal surface then where it goes into the bore before it starts straight down there are some scratches grind marks etc...on that little 45 degree type edge where it makes the transition into the bore. is this goin to hurt anything?? ill try and get pics up if i can. i can clean it up some if its usable but just wanna know if its a waste of time and money first. thanks
John
Old Oct 13, 2005 | 07:59 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What you have described won't hurt anything. I would only be concerned if there were scratches where the throttle plates touch the sides of the bore. Everything can be sanded out with a little elbow grease and a steady handy.
Old Oct 13, 2005 | 08:44 PM
Engine: 305 tbi l03
no the elbow grease wont be necessary i purchached a eletric die grinder and rpm controller to do the heads i got and i have unlimited carbide burs, flap wheels, sanding discs, and stones...well not unlimited but enough for this job anyway.
John
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
92camaroJoe
Aug 13, 2015 06:07 AM
