Has anybody tried one of these on their TBI?
Old Oct 24, 2005 | 11:26 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
It's the Holley Hi-Tek air assembly. I'm wondering about the fitment isses on the passenger side with all the hoses and stuff.
Old Oct 25, 2005 | 05:02 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Uh, got a bigger picture there Bill?
Old Oct 25, 2005 | 12:31 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Looks like a gimmick. Since the TBI gets air from all around the intake, it would seem to me that this assembly would restrict you to only getting ari from the sides as opposed to 360* all aorund.
Then again, what do I know?
Old Oct 25, 2005 | 02:57 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Clearance might be a big issue. You need something like 3"+ above the tbi to allow the pod and injectors to clear.
Old Oct 25, 2005 | 06:52 PM
azvolfan's Avatar
I'll see if I can find a bigger pictire.
Old Oct 25, 2005 | 06:59 PM
azvolfan's Avatar
Here's another pic.
Old Oct 25, 2005 | 07:00 PM
azvolfan's Avatar
an another
Old Oct 25, 2005 | 07:01 PM
azvolfan's Avatar
One more.
Old Oct 25, 2005 | 07:02 PM
azvolfan's Avatar
So what do ya think, will it fit. They retail for about $275 and there is one on ebay for @$100.
Old Oct 25, 2005 | 07:13 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
doesn't sound as if it will but, then again what do i know.
If that's what you wanted i'd buy it in a heartbeat. You could always make a spacer or something later if it didn't.
Old Oct 25, 2005 | 10:30 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I don't see how that will improve airflow. It looks as though most of the air would just pass through the filters and only very little would go down the neck. You would have to have that sucker on there tight in order to have a vacuum effect when the throttle opens.
Hell, it might even require a chip tune to adjust for the new enrichness?
Old Oct 25, 2005 | 10:42 PM
azvolfan's Avatar
I don't think the performance would be any different than an open element. I just like the look.
Old Oct 26, 2005 | 01:54 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Measure the hight of the pod and see if you can find some dimensions for the inside. The pod clearance is probably the most critical thing since it sits higher then a carb. The other thing to beware of is the fact that the cleaners themselves also have to clear the engine.
Its also neat, but one drawback is that it pulls air right off the headers, which in a hot climate may not be the best thing. TBI likes to have some heat, but that may be too much.
Old Oct 26, 2005 | 01:56 AM
Car: 88 Camaro SC
Engine: SFI'd 350
In the profile shot you could probably scale the hight off by using the opening for the carb as a reference point. IIRC its like 5.25" so that would give you a reference to determine the hight.
Old Oct 26, 2005 | 02:00 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Looks like its ~3.3" at the highest point. Might be a tight squeeze if it fits.
Old Oct 26, 2005 | 01:20 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Bill, my old roommate Justin is running one of those on his carbed car, I'm sure he'd let you borrow it for a while.
Old Oct 26, 2005 | 04:24 PM
azvolfan's Avatar
Thanks Tony. I'd like to just check out the fitment. What do ya have going this weekend?
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
