Need some help with a couple of things
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
Should i, what??????
I have a 1991 l98 sbc that i am parting out, and was thinking of installing it on my camaro that is an lo3 tbi, i want to stay with the tbi system. Would like to now what i need to do the swap like nock sensor, injectors,Etc. Also need to now if the harmolic balancer sopose to move frely, in meaning not the motor, but you know how the harmolic balancer has the inside part and the out side part, well the out side part moves. Does it suppose to do this?? Also whould like to now if the I could put my 081 heads on my l98?? I am running nitrous. thanks eric
Car: 1991 Chevy Camaro
Engine: 305 TBI
Re: Should i, what??????
The harmonic balancer is not supposed to move in that way, it is broken. The outer ring and inner ring have separated.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Re: Should i, what??????
Originally posted by Benm109
A stock LO5 PROM is not going to handle a L98 motor too well.
Engine: 5.7 tbi
Transmission: t5
Well if you look at my 90 camaro list in my signiture that is what is going to go on the 350. How about the 081 heads??? Are the heads on the 5.7 l98 already good???
_350 ESC module_ you mean by the module that is in the distributor? They are not the same?
Car: '90 RS
Engine: 377 LSX
Why would it differ???? The coil is the same, the distributor is the same???? At auto zone it has the same part #.
Engine: 5.7 tbi
Transmission: t5
I serched it, but does the tune port have that sensor or just the tbi systems have them?
Engine: 5.7 tbi
Transmission: t5
I currently have an lt1 cam in the lo3, sould i swap the lt1 cam into the l98? Or the l98 is almost the same cam? Or a better cam from crane, etc. I am alredy there so why not?
