TBI to TPI
Old Nov 8, 2005 | 06:10 PM
1992camarors's Avatar
Car: 1992 Camaro RS (Z28 Clone) Z03
Engine: 305 TBI
Axle/Gears: Eaton POSI/ 3.73
TBI to TPI
Has anyone ever swaped their TBI system to a TPI set up. I want to what parts would i need and how hard the task would be. I will be pulling my engine this winter to rebuild along with the rest ot the car. I have a 1992 Camaro RS 305 TBI 25th Anniversay Heritage Edition. Red with blacks heritage stripes.
Old Nov 8, 2005 | 06:59 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Welcome to TGO!
Yes, it has been done many, many times and is a pretty common swap. There is a pretty good tech article on this on the main page, check it out first:
https://www.thirdgen.org/newdesign/tech/tbitotpi.shtml
After that, try a few searches. All the info that you will need should be in past posts from people that have done this before. It's a common swap, so you should have no trouble finding out what all you need. If you still can't find answers, then post questions. The TPI board might be a better board to post in though, considering most of the guys here are sticking with TBI.
Old Nov 8, 2005 | 10:36 PM
NEEDforSPEED's Avatar
hope youd going with some diffrent heads and cam
Old Nov 9, 2005 | 04:59 PM
slowpoke89's Avatar
Car: 1995 Chevy camaro
Engine: 3.4
Transmission: at
tbi to tpi
so are they saying u cant do a tbi to tpi on a 1989 IROC is that a common swap ????
Old Nov 9, 2005 | 05:06 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: tbi to tpi
They are not saying you can't do it, but simply WHY? The TBI is not a restriction on a stock engine! Why spend more to get the same. Headers, Full Exhaust, Cam, Heads, and Chip work are the keys to power on your TBI engine. All of which are not going to be changed with TPI.
Old Nov 9, 2005 | 05:10 PM
slowpoke89's Avatar
Engine: 3.4
Transmission: at
im buildingt my first 383 for my IROC so not sure if tbi or tpi is best
Old Nov 9, 2005 | 05:59 PM
TBI is great, but for a 383 you'll have better luck with a TPI harness and ecm, just get a better intake.... "just MO"
Old Nov 9, 2005 | 06:11 PM
slowpoke89's Avatar
Engine: 3.4
Transmission: at
i need some opinoins then i have 1989 IROC 305 tbi 5spd ,gonna build 383 with t56 ,shoud i convert 305 to tpi now , or should i wait till engine swap heard its good to get the bugs out now then swap should go smoother ,thanx in advance
Old Nov 9, 2005 | 06:14 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
with a big cubic inch motor, I would not go with TPI, Something like a Stealth Ram would be better. (unless this is going in a truck, in which case TPI woudl be great, as the long restrictive runners are great for low-mid RPM torque.
Old Nov 9, 2005 | 07:54 PM
Dewey, thats what i was getting at when i a said diffrent intake....
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
