Up rocker ratio??
Car: 1965 Mustang
Engine: 347 stroker
Transmission: doing t-5 swap
Up rocker ratio??
Im doing minor mods to my g/fs 90 Firebird. I'd like to do a very mild cam. Do you guys know what the factory lift is on the cams for the 5.0 vin "E" TBI's? I thought maybe and easy way to do this would be to step the ratio on the rocker up a notch. Is the stock ratio 1.5? If so I figured on purchasing some 1.6 Rollers. Has anyone done this? What kind of lift will it gain? Will this hurt the valvetrain? Thanks!
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Its an easy swap, there will be plenty of clearnce room. The stock cam is a joke, something like .380 lift, or something really sad like that, it really isn't much of a cam at all.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A 1.6 rocker swap as shown great gains on these cars. Some people (user names escaoe me now) have dropped a full tenth off of their ET with this swap. The 1.6 rockers really help cylinder fill with the stock cam. I would not opt for the fancy full bodied roller units. Instead I would look at the stamped rockers with roller tips that are roughly just under $100.
Car: 1965 Mustang
Engine: 347 stroker
so this should put the lift around .400 lift or about what should I expect? To me doing this just really beats putting a cam in....if it was my car yeah I'd be pulling the cam but its my girls and she isnt as much of a motor head......not yet anyway
....so I would love to opt for the 1.6 Rollers.
Do you recommend any part numbers Shifty?
Just like some Summit Racing specials??
Why do you advise to not go with the full bodied roller rockers? I am very curious about this.
....so I would love to opt for the 1.6 Rollers.Do you recommend any part numbers Shifty?
Car: 1965 Mustang
Engine: 347 stroker
Also does that thing have 3/8" studs or 7/16"?
Do you guys adjust them like I do my Ford? Top of lift....down hand right then half a turn? I dont know if GMs are different or not...like I say this is a learning experience for me.
Car: '90 RS
Engine: 377 LSX
Check the LT1 cam digest above for proper valve trian adjustment. It is described towards the bottom.
To figure our your new peak lift take the old lift value and devide it by the current rocker ratio; .380/1.5 = .253. Now multiply it by the new rocker ratio; .253*1.6 = .405
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Cam is worse than that.
10088155* .350 .384 179 194 109.0 (108/-112)
Made me want to die inside when I read that.
Damon
Sep 26, 2015 04:29 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
