mounting external ignition module
Old Nov 29, 2005 | 07:57 AM
75 wagon's Avatar
Car: 75 Jeep Wagoneer
Engine: AMC 360
Transmission: TH400
I am in the process of converting a large cap HEI to ecm controlled HEI for my TBI setup. I am using an 8 pin ignition module and was wondering if using some dielectric silicone grease (whatever it is called) and mounting it to the firewall would be enough, or should I mount it to some sort of CPU heat sink? TIA
Old Nov 29, 2005 | 12:24 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
It woudl be ok to externally mount it. But, the surface must be able to conduct a good deal of heat and also have a very good path to ground, or the module will malfunction/not work. Also make sure to keep wire runs as short as absolutly possible.
Is it possible to modify the dist. base and mount it internally?
Old Nov 29, 2005 | 12:43 PM
75 wagon's Avatar
Engine: AMC 360
Transmission: TH400
To get it to fit internally would require a fair amount of cutting and the heat soak area on the ign module area would not be totally on the heat transfer pad in the dizzy - it would sit upside down on it.
Old Nov 29, 2005 | 01:28 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Definatly would have to sit on the metal contact pad underneath. Itll have a meltdown, otherwise. Probably doesnt really matter in the long run where it goes so long as the wires arnt too long, it has a good ground, and can stay cool.
Old Dec 2, 2005 | 02:58 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
people used gm's 4 pins with a Ford duraspark distributor in their mustangs. They mounted the module to a heat sink and put it on the firewall
BRoss99
Aug 10, 2025 05:08 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
