gp sorenson tbi injectors?
Engine: 355 6"rod tbi - in the works
I already ran a search, couldn't find much.
Are GP Sorenson tbi injectors any different than OE GM tbi injectors? they look new. Do they hold up to high fuel pressure fine? I can get two 17113080's for $90 at advance, which are out of a 94-95 454 tbi truck, so I assume they are 80lb'ers?
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
they should hold up just like the originals, but im sure it will have a shorter life span. OE aftermarket isnt always as good as the real deal. you also need to look at the fact that they might not be a matched set for fuel flow.
Car: check
Engine: check
Transmission: check
Re: gp sorenson tbi injectors?
RBob.
