Hope its your common prob.....
Old Dec 19, 2005 | 04:16 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Well guys the car runs real great and all. I have done cap, rotor, wires, and plugs. I plan on doing a fuel filter and maybe a IAC soon. The thing that just began to happen is a tiny surge at idle. It is not like a 800000000rpm surge, it just goes from like normal for a few seconds and then to like 800rpm for a sec and then back down for a few more seconds then back up. Is there anything I am overlooking possibly?
Old Dec 19, 2005 | 04:23 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
either a vaccum leak or stuck egr valve most likely. Is your check engine light on?
JPrevost's Avatar
Car: 91 Red Sled
Sounds like a lean surge, very slight. If the surge is methodical then it's fuel, if it almost stalls then quickly jumps up then it's too much timing.
Change your fuel filter and retest.
Old Dec 19, 2005 | 04:48 PM
Engine: LB9, LB9
There is no check engine light, and it happens consistent. The car has 175,000 miles if that makes a difference.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LC2 TECH
Oct 13, 2015 11:53 PM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
3.8TransAM
Oct 1, 2015 07:47 PM
