Answer to Open Air Filter???
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Well ive been searching on here for 2 days and i really havent gotten a clear answer to this, what air filter is actually the best for this. Meaning like brand and size from carb flange and is raised dropped or flat the best for this application. looking on here most people seem to say go with flat but the only one i have found is the summit brand one, and it says it has no spot for the PCV. i just want to know which one to get exactly part numbers would be great.
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I actually just ordered the K&N 14x3 open element with the slight raised base. Im not sure exactly how high its raised, but not by much. It is expensive but im sure its gonna be worth it. 14x3 is the common one though.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
well i went out and bought a "holley high proformance air cleaner" part number 120-102, 14x3 now im just wondering if it will fit, on summit it says it has a drop distance of 1 1/8. so im just wondering if this one will fit.
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I have the Edelbrock Pro-Flow breather. My car is so loud now. I believe i actually notice a small difference too.
Just goto advanced auto parts and buy it from them. $24.88 Same as summit racing without the shipping cost.
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
I bought a Moroso drop base from Summit, I could notice an immediate difference. And it sits a little lower than the stock cleaner, not problem with it touching anything.
Car: 91 Camaro RS
Engine: 305 tbi
I bought a K&N from bbtaz97 im not sure what size it is you can ask him he can probably tell ya but it doesnt come close to touching anything and it fits under the stock hood
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Most filters that you buy will not have the hole for the IAT sensor. You will have to drill out a hole for that. Most cleaners do have a round dimple in the stamping that shows you where to put it.
You want to shoot for a non drop base 14x3 (or 14x2") standard open element.
Engine: LB9, LB9
The punch out for the IAT is the thing where it is one big circle in the middle of two small ones right?
Mr. Gasket 1480 is what I used on my stock LO3 with the stock Hood. Its has flat base and is a 14 inch x 2inch filter. Cleared the cap and wires and fit under the hood.
Car: '90 RS
Engine: 377 LSX
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
I used the Summit 14 x 3 flat base (p/n SUM-239341, $49). It worked fine, although the 3" filter is a tight squeeze under the stock hood. It comes with the IAT hole already formed in the base, no drilling required. You won't run your PCV into the filter any more, just get a separate little crankcase breather you can buy at any auto supply store.
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Shifty i PMed you regarding an open element that i want to get and to see if it would work..but you never got back to me!?
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
Well i use a Specter 14x3 cleaner from autozone with a K&N filter, the filter is the closest to fit, its a little big but if you squeeze it in their it works.
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
I live in a pretty cold place (Quebec , Canada) . Do you think a open air filter element will work well in my Bird ? And what should i do with the PCV and the air temp sensor ?
Car: 91 Camaro RS
Most open elements come with a knock-out for the inlet air temp (IAT) sensor. If it does not have one, just drill a hole in the base the same size as the one in your stock base.
Don't try to run your PCV back into the open element air cleaner. Just use a small separate filter like the one in the pic below. You can pick one up at any auto parts store, Summit, Jegs, etc.
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Honestly dude, if you do a little bit more research right here on TGO, not only will you find that this SAME question (not the general Open Element question, but your not getting the answer you were looking for question) has been asked a gazillion times, but it has been answered too. So whomever reads this thread, and doesn't find the answer they were looking for, just search a little bit harder
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
