Engine Error Codes
Old Dec 20, 2005 | 08:52 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Engine Error Codes
I DID A CODE TEST AND I GOT THE FOLLOWING ENGINE CODES BACK.
44,32,23
IF YOU HAVE ANY ADVICE ON HOW I CAN FIX THIS PLEASE ELP, THE ENGINE IS A TBI
Old Jan 1, 2006 | 10:10 PM
91Z28TTOP's Avatar
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
This info is from a Haynes book.
Code 44 means a lean exhaust condition caused by malfunctioning fuel injector, vacuum leak, low fuel pressure, etc.; poor electrical connection, open or short in circuit; defective MAP sensor, defective O2 sensor; defective ECM.
Code 32 means EGR system, restricted vacuum hose to EGR solenoid or valve, open or short circuit; defective EGR solenoid; defective EGR valve; defective ECM.
Code 23 means Manifold Air Temp sensor is faulty, poor electrical connection, open or short circuit; defective MAT sensor; defective ECM.
In a nut shell replace the O2 sensor, check vacuum lines. Remove EGR valve and inspect the passages, and valve. Most of the time a can or 2 of carb cleaner will clean up the valve and passages. Then replace the MAT sensor. Then after everything is replaced disconnect the NEG terminal for about 5 minutes to clear out all the bad codes and fire it up warm it and test it for codes again.
Post you findings and we'll take it from there.
Old Jan 1, 2006 | 10:46 PM
Engine: V8 350 ci
will do thx
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
