Engine Error Codes
Old Dec 20, 2005 | 08:53 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Engine Error Codes
I GOT A 305 TBI, MY CAR IS MESIN UP SO I DID THE CODE TEST , AND I GOT THE FOLLOWING READING'S
44,32,AND 23
IF YOU KNOW WHAT THE PROBLEM MAY BE WITH MY CAR PLEASE HELP
Old Dec 22, 2005 | 05:56 AM
honken's Avatar
Car: El camino 70 ss
Engine: corvette lt1 94
http://www.troublecodes.net/GM/
Old Dec 22, 2005 | 08:55 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
code 44,You`re running lean, code 32 check your egr valve, code 23 your iat sensor is either dead or unplugged(the sensor that is on the bottom of your air cleaner)
Old Dec 22, 2005 | 02:27 PM
Engine: V8 350 ci
how do i fix teh runing lean part?
Old Dec 23, 2005 | 08:30 AM
well running lean can be any number of things ; i.e. vacuum leak,bad o2 sensor,not enough fuel pressure, so on and so forth. How long has it been since your o2 has been changed? I would check that first.
Old Dec 23, 2005 | 11:41 AM
Engine: V8 350 ci
its never been chaged that i know of. how do bi remove the wires comoing ouy of the h2 sensor, it seems to lean into a buntch o wires. do i splice into the wires? thx for the help
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
