Open Element Vacum Plug
Old Dec 23, 2005 | 01:30 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
What have you guys used for a professional looking vacum plug or cap that I can find at a standard store? I searched and read the open element FAQ but its just so much damn reading.
Could you guys post pics if you can?
Dimension would also help.
Old Dec 23, 2005 | 03:49 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I went to carquest and asked the guy for vacuum caps and he lead the way lol. It was one of those HELP products and came with several caps.
Old Dec 24, 2005 | 08:51 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Go to autozone and go the the isle where they have the "HELP" section of stuff. Look for a pack of vacuum caps. They are cheap there are all sorts of sizes in there.
Old Dec 24, 2005 | 09:01 AM
Engine: LB9, LB9
Hey shifty, do you know what size it is cause I crammed the 1/8 plug on and it wont go all the way on but its tight, then I tried the 7/32 and 3/16 and they were too loose.
Old Dec 24, 2005 | 09:54 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It has been a long time since I did that. I think I just found one that fit on tight and didn't make note of its size. The 1/8" should work. I don't think any plug will go on all the way.
Brinkkl2000
Aug 4, 2018 08:29 AM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
