X-Fire 83' What is this?
Old Jan 13, 2006 | 02:45 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
My buddy has just aquired this and there is a black plastic cylinder thingy above the master cylinder on the firewall.
What is it ?
It appears to have a vacuum line and a cable coming out of it.
Cable looks to go into the cab.
Any ideas ?
TIA
Old Jan 14, 2006 | 09:24 PM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
got a picture?
Old Jan 14, 2006 | 10:58 PM
JP86SS's Avatar
Camaro BTW,
Had one but couldn't get the scanner to work.
Its in all of the haynes and chiltons but doesn't say what it is.
I might have to go over there and take a closer look.
Its right out in the open on the pic.
Sits horizontal just above the brake booster. He told me it had a vacuum connection on one end and a cable coming out the other side.
I'm wondering if it might be an early EFE actuator or something.
Old Jan 15, 2006 | 12:23 PM
Car: Trans AM
Engine: 305 TBI LO3
cruise control part maybe?
Old Jan 16, 2006 | 03:28 PM
Damon's Avatar
Shaped like a little plastic mail box? That's your HVAC vacuum reservoir for the early model 3rd gens. One rubber vacuum line in from the intake manifold, one small plastic vacuum hardline out to the HVAC controls under the dash.
They sometimes crack and become a massive vacuum leak, causing rough running for the engine. Ask me how I know.
Old Jan 17, 2006 | 10:02 PM
JP86SS's Avatar
I think you are right on that. I suspected some kind of heater control but neversaw anything resembling that before.
He's got a real rough idle that won't calm down.
I'll probably take a look at it tomorrow.
Thanks,
Jp
Old Jan 30, 2006 | 11:21 AM
JP86SS's Avatar
Still guessing
We thought it was the vacuum canister like Damon said but then he found the "orb of power" behind the headlight.
I haven't been over there but here is the picture of it.
What could this thing be?
Old Jan 30, 2006 | 01:17 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
that right there is for your HVAC system.. the large hose goes to a vacuum source, the small plastic hardline (what you think is a cable, but is really a hard plastic vac line) goes to the hvac controls in your dash like stated above.. I know this for fact, since all three of my camaros have the same exact thing, and i just got done replacing that hardline vac to the controls on my '83.
Old Feb 3, 2006 | 10:09 AM
Damon's Avatar
If you have cruise control that's why you also have an "orb of power." Trust me, the "mailbox" is for your HVAC controls.
Old Feb 3, 2006 | 04:53 PM
JP86SS's Avatar
Thanks again for re-confirming that.
John
MrBill
Aug 4, 2008 02:40 PM
matt_82transam
Feb 2, 2004 01:21 AM
bad91lx
May 19, 2003 09:58 PM
Jason86Z28
Mar 6, 2002 10:04 PM
