Options for heads?
Old Mar 6, 2002 | 06:14 PM
Jason86Z28's Avatar
Options for heads?
Here's my engine specs as of now...
engine: 350 Goodwrench engine
cam: Comp 206/212 @.050" .425/.442
heads: stock goodwrench
exhaust: flowtech shorty headers, !cat, 3" pipe to '98 WS6 Muffler
ignition: MSD 6AL
What kind of heads would everyone reccommend I go with? Can I use any standard set of heads, or do I need special ones for the X-Fire intake? I was thinking of maybe getting the Wolrd Products S/R Tourqer heads. They're a fairly mild head, but I've also got a mild cam in there.
Also, what kind of power do you think I'm making w/ the current setup, and how much of a gain would I see w/ certain heads?
I entered my engine/induction specs into Desktop Dyno and its saying I'm making 282 Flywheel HP @ 5K and 305 FW TQ @ 4500. Does that sound about right? For the specs I put in a SBC 350, 441 Heads, 8.5:1 compression, 510cfm 2 bbl carb (as close to 2 1bbl TBI's as I could get), Tunnel Ram intake (thats what a cross ram is, right?), Small tube headers w/ mufflers, and my cam specs.
Old Mar 6, 2002 | 06:32 PM
MorgRS's Avatar
Try this place..might give ya some ideals
http://www.ryanscarpage.50megs.com/combos1.html
Old Mar 6, 2002 | 09:12 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd recomend a set of trick flow's. they are available at a pretty decent price and 64cc chambers will help.
Old Mar 6, 2002 | 10:04 PM
Stroked-Z's Avatar
All depends on your budget/idea of how you want the motor to run.
IMO, there is no point in getting a set of killer flowing heads when you'll be using a very mild cam ect....
Budget project, go Vette Aluminum or Vortecs.
Serious, look into aftermarket.
My 0.02 cents.
italiano67
Dec 11, 2016 09:21 AM
RedLeader289
Jan 22, 2016 03:05 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
ydnar417
Sep 23, 2015 05:57 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
