Size screw pressure regulator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i beleive it was a 1/4 20, is what i remember reading somewhere but, don't quote me on it....
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
Originally posted by Raul_Chile
I saw it, but my question is which exactly screw need to install or replace.
I just finished converting my stock fuel pressure regulator into an adjustable one. To remove the stud from the spring cup, I had to grind the end out with a dremel becasue it was welded or brazed to the cup at the factory. Instead of putting a slot in the screw, I made a new screw out of aluminum. The threads that screw into the spring platform are M6 x .75. This is a fine pitch M6 thread. At the opposite end of the screw (the end the tech article says to grind a slot) I drilled and tapped a M4 x .7 blind hole, which I screwed and loctited in a M4 x .7 socket head cap screw about 1 inch long. The cap screw to sticks out the bottom of the TBI (just above the MAP vacuum port), allowing me to adjust the regulator pressure on the fly without removing anything. Works great.
For simplicity, just follow the tech article. The only drawback is that once you've reinstalled the FPR, you'll have to take a few things back apart to make an adjustment to the fuel pressure later. Only takes a few minutes, so no big deal.
