Exhaust ? Waiting for ebl...
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
I'm not going to start programming stuff myself until the EBL comes out and was wondering if I'll be fine when I get my headers and duals on there (they're finally coming I'm pumped
) without touching anything until the EBL comes. How drastically does this affect things? Right now I'm running a rough tune from tbichips.com. I can send before and after logs if anyone needs. I'm not very good at reading them but from what I can tell right now it runs a bit rich until it warms up (123 BLM) then once its at operating temp it sits right at 128. The exhaust should be on by the end of Feb at the latest unless something rediculus happens and one of my parts doesn't come in on time.
) without touching anything until the EBL comes. How drastically does this affect things? Right now I'm running a rough tune from tbichips.com. I can send before and after logs if anyone needs. I'm not very good at reading them but from what I can tell right now it runs a bit rich until it warms up (123 BLM) then once its at operating temp it sits right at 128. The exhaust should be on by the end of Feb at the latest unless something rediculus happens and one of my parts doesn't come in on time. Member
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
I've haven't had a chance to read through all 6+ pages of the EBL thread. Have they said what the expected release date is an a rough cost? I think all DIY TBI'ers are anxiously waiting for this software.
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by brodyscamaro
What does EBL do?
What does EBL do?
Nitrous Control
2-bar MAP
Rev limiter
Speed Limiter
Shift Light
Smart A/C clutch
PE Active Output
Are just a few of them.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
2-bar MAP lets you run boost (turbo, SC, blower, etc). Basically the ecm will register manifold pressures over normal atmospheric pressure at sea level. Youll be able to run up to ~14 psi of boost and have the ecm account for it.
Engine: 355
Transmission: 4L60
Sounds good but we already run into fueling problems with just N/A motors. Guess I'll only be using 1 or 2 of the additional features, wish they would turn something like the speed limiter into the control for the EVAP system seems more of a PITA to have removed this feature above all others. EGR and the rest don't really matter but I can't see anyone wanting to ditch EVAP.
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
you always run rich on startup, it's called open loop. Your computer doesn't follow any readings from sensors in open loop, therefore it works on a set perameter which is usually pretty rich.
Once at operating temperature you are in what's called closed loop. This is when the computer starts taking the 02 sensor readings to help give you the perfect 14.7 to 1 a/f ratio, when you hook them up to a scanner an easy way to sorta kinda check if the 02 is working properly is it will keep changing from lean to rich nonstop to maintain a very close to 14.7 a/f ratio..
Engine: 355
Transmission: 4L60
Well that explains that, but what is this exhaust going to do to my car, going from a single 2.5" pipe with factory manifolds to headers w/ dual 2.5" is a huge difference.
Car: 1983 G20 Chevy
Transmission: 4L60
Engine: 355
Transmission: 4L60
Originally posted by Fast355
TBI G-series vans did not use a canister purge solenoid, the canister has 2 ports, fuel tank vent and ported vacuum from the driverside of the TBI. As long as you are above idle there is vacuum on the canister and it purges.s
Car: 1983 G20 Chevy
Transmission: 4L60
Just take the solenoid out, use a vacuum line reducer (can't think of the name, you can get them in the HELP section at Autoparts stores). Then run the hose to the driverside front fitting on the TBI.
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Some people say they do runner leaner which i could beleive but, if they do, it's not enough to realy worry about i wouldn't think.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
sailtexas186548
Feb 17, 2017 03:07 PM
