Old school vs new school timing Q's
seems a mechanical distributo would idle 6-10 deg A. yot in the tables i see in our cars are 20+ ded A at idle.
why are we running more at idle and off idle at tip in?
one more not related.
why does a mechanical distributor have a centrifugal cam /weight system in addition to vac assist? does the vac assist provide more A that the weights cannot provide?
some where along the way i thought some vac assist actually retarded timing at WOT or 100 MAP(min vacuum) ? in that it would prevent detonation?
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Re: Old school vs new school timing Q's
why does a mechanical distributor have a centrifugal cam /weight system in addition to vac assist??
You need an rpm-dependent way to allow timing to change, and a load-dependent way for timing to change.
Yes.
Mech advance, via springs and masses, is completely rpm-dependent. You need more advance, typically, at higher speed because combustion occurs slowly, so at higher rpms you have less time to get the job done. So you have to start burning earlier to get the optimum work from each combustion event.
Mech advance "knows" zero about how loaded the engine is (i.e. are we at part throttle, or WOT?)
Vac advance is a way to measure load so it makes up for what mech advance can't do. More vacuum means the throttle is more closed, so there is less load on the engine and hence less need for power. Less vacuum (higher MAP) means more power is needed.
In addition to these two, you also have the static timing set by fixing the distributor angular position w.r.t. #1 cylinder. HTH.
please comment as to why most timing tables for our TBI cars and TPI as well idle 20+A vs mechanical at 6-10A ?
ps i had my car at 10 at idle and off idle for a while trying to cure bucking. turned out was lean or car liked richer A/F ratios so returned to 20A for idle. what is the reason to run more adv at idle in our cars ?
Car: 1983 G20 Chevy
Transmission: 4L60
Well lets see, my stock distributer from my van was set at 8* BTDC. It had a 20* vacuum advance canister connected to manifold vacuum. It then had 18* of centrifical advance starting at about 1,800 RPM and ending at about 4,400. That is about 28* at idle, 26* @ WOT and 4,400 RPM. At a typical cruise speed of 2,000 RPM the timing varied between 10-30* depending on engine vacuum.
Car: 1983 G20 Chevy
Transmission: 4L60
Well I tried to add this but it wouldn't let me, trying again.
Engine: LO3, LO5
Are you sure the mechanical has only 6<sup>o</sup> to 10<sup>o</sup> of advance? IIRC there are small vacuum advance "cans" using an intake manifold ported vacuum line that cause the timing plate inside the distrib to rotate with a change in the vacuum. So isn't there both mech and vacuum portions that provide advance even at idle on a std distributor? And that btw would be on an engine with NO ECM whatsoever.
On an engine with an ECM, like as used on a CCC (or especially on TBI and TPI), things might be different as to how ignition advance is applied, because it would depend on what sensors are available and what could be stored in a lookup table in the EPROM (assuming there is one).
On a TBI and TPI, you have advance curves preprogrammed for change with rpm, as well as an adjustment based on MAP (which is an inverse way to measure vacuum).
The only real difference I can think of between two identical engines, one with EFI and an ECM, and the other that is controlled in an old-school manner (using centrifugal mech advance and vacuum advance) is that the ECM version can monitor and control (enforce) a desired engine rpm even when the AC is turned on. The mech system doesn't have any feedback means to do this. So if you loaded up the old-school engine at idle it might stall.
Really old engines had a timing adjustment that could be made from inside the car. It was a mechanical linkage on the dash that allowed different timing for starting, and then you moved it when you wanted to actually go somewhere (loading the engine and running above idle).
thanks for the answers. let me see if i have this clear.
mechanical dist base timing is set say 8 deg A. at idle the vac canister(adjustible) provides more timing moving it to say 20 deg? the centifical system provides little or no timing input at idle. as rpms increase say 150-2000 rpms the vac canister provides less timing(less vac) and the centrifical adds timing. offset? at wot the vac is nil(100 map) and the certrifical advances as the rpms grow. eventally the centrifical is maxed out. please correct me or add to this.
now at 6000 rpms would you not want some retard? how would that dist handle that?
this sounds like engine therory 101.
Engine: LO3, LO5
I can only confirm if you understood what I think I wrote..... it doesn't mean, necessarily that *I* got it right myself.
Check.
Mostly correct. You could be driving on the highway at steady part-throttle cruise. So you might still have a lot of engine vacuum.... which means there really isn't much load on the engine. So the centrifugal springs/wgts will add advance in a linear fashion between two rpm set points, the set points being determined by the masses, the springs, and how far away from the dist shaft they are positioned.
Correct.
Do you mean that, if redline was 5500, that you would intentionally want some retardation on the ignition to prevent over-revving past 5500 rpm? If so then yes.
How was it implemented, if at all ? I can think of a secondary set of springs and masses that would rotate the timing plate in the opposite direction of advance at a high enough rpm but I don't know if any mfg ever implemented a caveman rev-limiter like that.
this sounds like engine theory 101.
somewhere i read a mechanical dist with VAC can remove timing as well? maybe i am wrong on that. my buddy removed the vac can by sealing it off? that leaves only mechanical? not sure why he would do that.
Engine: LO3, LO5
no. i mean that engine pulls to 6000 where max HP resides. and can i assume it is 100 MAP? .... i assumed maybe falsely that was to reduce possibility of detonation? also i dont think engine needs 36 d A as load is lessening at higher rpm shift point(ran outta gear).
Ahh. Well MAP is peaked so the vacuum-control is of no use. So it would have to be a secondary set of springs/wgts that back off some of the advance.
The mech aspect could, yes, for example in the manner I described. I doubt the vac could do much for you though. The vac will peg at 1 atm when you go WOT, no matter what the rpm. So only engine speed can help you to alter the timing.
......... my buddy removed the vac can by sealing it off? that leaves only mechanical? not sure why he would do that.
It wouldn't be a good idea to do this on a street driven car, unless you have a really lumpy cam and the car is more suited for the track than street use.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
This was my stock one:
Between the adders (cool comp, PE and the slope), I'm looking at about 20° at 4800rpm. Do you think that's right? What a funny looking spark curve, too. The one in my Camaro actually looks like you'd expect. Smooth and gradual everywhere.
lars grimsrud is a legend amongst old school corvette enthusiasts.
here's a link to his hei paper.
http://members.shaw.ca/crussel/hei/HEIPrimer2.html
as i've learned from this forum, some of this doesn't apply to SP fast burn heads.
