Head Gasket... HELP!!
Old Feb 14, 2006 | 01:28 AM
1991 RS 305's Avatar
Heads are back from the machine shop. 56cc is what they have been milled to. Does anyone know the dish in CC's that the stack piston is on the LO3? How about how far the piston sits in the hole at TDC? I have been looking for this info all over the net/ manuals and cannot find it. Anyone know the thickness of the stock gasket for sure, is it tin or composite? If anyone has this info you'll be my hero. I know I could probably run a tin (shim) gasket that is .015", but this may mess up my quence. This would probably leave me at about 10:1 compression, which would be cool, but not if the quench is messed up. I will run a thicker composite if necessary, but I want to go with at least 9.5:1 compression.
One other question... will I need new intake bolts for the vortec intake?
Any help here is appreciated, I'm in a jam until I get this squared away.
THANK YOU, Matt
Old Feb 14, 2006 | 02:27 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Stock they "should" be .025" in the hole. not "should" is in quotes.
If you have the heads off, it is easy enough to check. going with a .015" stock style gaskets, puts your right at .040" quench. Most peopel shoot for .036 - .040 quench, so you are right where you should be, but on the safe side, considering you are running on older rods, i wouldn't want to push the quench threshold. This way you ensure that there will not be contact between pistons and heads.
Old Feb 20, 2006 | 09:18 PM
Do I need the gaskets for the 305 or for a 350. Heads are off a 350 , but milled to 56cc, i'm putting them on a 305. I have read both ways in my searches. Also, I am leaning towards the .015" shim gasket. The block has 130K on her. Anyone think I'll have any sealing issues?
Thanks, Matt
Old Feb 20, 2006 | 09:28 PM
Dewey316's Avatar
Car: 1990 Camaro RS
I used the shim gasket with no issues at 197k. If you are worried, make sure you copper coat it. Then warm it up to temp after you are done, and then let it cool down, and retorque. You should be fine then.
IIRC I used fel-pro 1094 for mine. Do make sure you do a GOOD job of cleaning the surfaces of the head and block.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
