L03 Cam specs?
Old Feb 17, 2006 | 09:44 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
L03 Cam specs?
What is are the lift and duration specs on the stock L03 cam?
Old Feb 17, 2006 | 09:47 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
junk for short but, look at the tech section for exacts. I think i remember reading 180s for duration and sub 400 lift at the rockers....
better off as a paperweight....
Old Feb 17, 2006 | 10:08 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Wow...man. That is crappy. Compared to the modest LT1, that is....crappy. lol
Old Feb 17, 2006 | 11:49 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
hmm something like hmmm .380
Old Feb 17, 2006 | 11:55 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
178/194 @ .050, .350"/.385", 109* lobe seperation installed at 112* intake centerline.
Old Feb 18, 2006 | 12:14 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Wow. The LT1 is 279 int, 276 exh @ .447 int, .459 exh. Not sure about the LSA or intake centerline.
With a moderate to good tune, what kind of power increase can I expect from the LT1 cam. I am replacing the springs and the timing chain assembly when I do it.
I am thinking about getting a tune from PCMforless. Would that get me rolling ok?
Old Feb 18, 2006 | 12:26 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
No, the LT1 cams are around 203/207 @ .050, .447/.459, 116* lobe seperation on a 112* intake centerline
Old Feb 18, 2006 | 12:29 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Oh. I got that info from a LT1 Corvette site. Is there a difference between the Vette and F-Body cam?
How about the tune? Will the car be drivable/perform well?
Old Feb 18, 2006 | 12:44 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
With a good intake, exhaust, and tune the LT1 cam will make the little L03 perform alot better. It will take a good tune though.
The F and Y body LT1 cams are very similar and in some cases the same.
You are looking at the cams advertised duration. I am going off .050" specs.
I see no mention of exhaust on your sig. I would suggest replacing the exhaust from the heads to the exhaust tips. A stock L03 truck or even a 4.3 LB4 TBI V6 truck came with 3" exhaust from GM where the F-bodies came with 2.25".
Without exhaust mods, I would actually recomeend the Vortec 305/350 truck cam over the LT1 cam. There are thousands of them out there for CHEAP, they make good power with a somewhat restrictive intake and exhaust, and WILL run well on the stock tune, IN MY EXPERIENCE.
Old Feb 18, 2006 | 12:49 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I am planning to get some Hooker Super Comp shorties and full 3 inch exhaust (cat-back) in at the time or before I put in the cam. I am also looking at a 1" TB spacer, a 1/4" injector spacer, and a adjustable FPR....if I can get the guy to e-mail me back.
Would that cover me in the intake area? And would the PCMforless tune work for me? I have heard from several people that they are good at it, but I've not heard from any TBI guys.
Old Feb 18, 2006 | 10:38 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
what would this be with 1.6 rockers?
Old Feb 18, 2006 | 10:51 AM
91RockS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
With 1.6 rockers the lift goes up by a factor of 1.6/1.5 (which equals 1.067). In other words, you'll gain about 7% lift. So .350"/.385" will end up .373"/.411". Duration will go up slightly with the 1.6 rockers.
robertfrank, any timeslips with all your mods? Curious if you've broken into the 14's.
Old Feb 18, 2006 | 12:00 PM
no time slips as of yet.I live to far away from a drag strip.Some friends of mine are going to find a long strip of flat road and map out a 1/4 mile with some spray paint.We're getting some stop watches to track the times.i know it won't be totally acurate but it will give us at least a guesstimate.
Old Mar 16, 2011 | 08:15 AM
mikesanto70's Avatar
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
Re: L03 Cam specs?
I'm doing a 4th gen 3:42 swap too, did it wake it up at all?
Old Mar 16, 2011 | 10:09 PM
Re: L03 Cam specs?
holy ****!!! it's a zombie thread!!!! lol. Yes 3:42's will wake it up.
Old Mar 17, 2011 | 02:22 PM
Engine: L99 L98
Re: L03 Cam specs?
I guess so, that was 5 yrs ago, do you still have your RS?, also, did you need to swap in a master cyl, power brake booster, or proportioning valve from an LS1 Camaro to make the combo work right
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
ericjon262
Sep 11, 2015 06:07 PM
angel2794
Sep 8, 2015 06:22 PM
Formula_88AE
Sep 3, 2015 01:47 PM
