resetting computer
Old Feb 20, 2006 | 05:55 AM
KamaroKyle91RS's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 350 TBI Small Block V8
Transmission: Automatic
resetting computer
how do i go about resetting the computer on a 91 RS with a 350 TBI?
(Cross-Posted to Tech / General Engine)
Old Feb 20, 2006 | 10:10 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
disconnect the negative battery cable for a minute. It'll clear all the codes stored.
Old Feb 20, 2006 | 12:06 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
KamaroKyle91RS
you have a 91 RS with 350 TBI? You must have upgraded from a 305 correct?
Old Feb 20, 2006 | 12:40 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
The 1991 RS has a standard automotive fuse located near the negative battery post. Should be mounted on the fender upper core supprt (is that the right name for it?). It's in a weatherproof black shell which you'll need to open to get to the fuse. Pulling the battery connection will work just as well if you don't mind losing clock settings, etc. on your radio.
One thing of note, though, I'd recommend pulling the + battery cable because some electronics don't particularly enjoy losing their ground.
Old Feb 22, 2006 | 01:30 PM
blackroc68's Avatar
THAT fuse is the fuel pump fuse on the support
Ed1LE
Sep 30, 2018 09:14 AM
okfoz
Oct 13, 2015 02:19 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
