Wire ends
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Wire ends
Ok well my Crane Cams firewires came with grey boots on the end which I figure are for distributor. Well the HEI ends you have to cut the end off and do both ends of the wire over. Since I have extrernal coil, woukd I be fine using the regular ends that are on there now?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As long as the terminals are properly prepped and crimped onto the wires it doesn't matter what angle fitment you have.
Engine: LB9, LB9
I just dont want to cut the premade end off to put the dumb hei boolts, especially when I have an external coil and no clearance issues.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If the wires fit, then use whatever end is on there so long as the wires have the correct terminals for the later HEI dist.
db057
Aug 11, 2015 10:11 PM
