305 Bored .060 Over?
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
i was browsing the pages and came across this website that has all engine sizes specifications. and i never new a 305 could be bored .060 over which becomes a 315 cubic inch and not just be bored .030 over to become a 310 cubic inch. i remember seeing something on TGO that you couldnt something about coming close to the walls. not sure. can anyone verify this for me? heres the link. check for your self http://www.chuckschevytruckpages.com/enginespecs.htmlthanks
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Some blocks with no core shift can probably bored out .060 or perhaps even more. Some blocks with core shift probably can't.
Boring isn't done to increase displacement, it's done to clean up worn cylinder walls.
Car: 91 Camaro RS
Engine: TBI
I'd have to get into my books but i believe .030 is the max you can SAFELY go on a 305 before you start getting near the jackets, its been awhile though
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Originally Posted by Fast355
Depends on the 305 block. I have 2 305 blocks in my garage that are VERY thick castings(Sonic checking says .450" in the thinnest spot, and the block is already .040" over). The virgin block is almost .500" in the thinnest spot. The .040" over 305 took forever to warm up with the thick walls. Both out of 3/4 ton trucks/vans. One is 4-bolt main. Maybe you can only go .030" over on F-body blocks, but .080" over pistons are available for the 305. Another ounce of proof, is most 350 blocks weigh right at 200 lbs bare. This bare 305 weighs 230 lbs.
TheTraut88
Sep 7, 2015 05:22 PM
