My idle is very rough
Car: 97 b4c camaro
Engine: 350 lt1
I have a all stock 89 305 tbi and when my car idles it will raise to about 1,100 revs and then drops down to about 750 or so and it does it constantly up and down up and down and it will stop when I put it in gear. Do I have a problem or do I need a tune-up? If someone knos let me kno, thanks.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Check your base timing and all vacuum lines. Look closely at the TBI gasket. That is a common source for leaks. It wouldn't hurt to pull the TBI unit and clean the funk out from around the IAC (and vacuum passages). Refer to Dimented24x7's IAC instructions posted towards the bottom of the "new to TBI sticky".
