what lines/passages to clean on TBI?
Old Apr 23, 2006 | 03:36 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I've read a little about cleaning certain sensors or tubes in order to hopefully fix problems with the Idle, but I'm not sure of what lines/sensors i can clean to see if it helps...what lines around the TBI should be checked?
Old Apr 23, 2006 | 11:25 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The passages under the TBI, the PCV system, and the EGR passages are the only things that really build up carbon deposits. Also check that the EGR moves freely and isnt handing open if you take it off to clean the passages.
Old Apr 24, 2006 | 05:37 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
a rough idle could be a result of carbon build-up in the iac valve. i was going to explain to you how to clean it, then i remembered that i found a thread explaining better than i ever could. good luck and hope it helps.
Cleaning IAC Valve
Old Apr 24, 2006 | 07:53 PM
Car: 1988 SC Camaro
Engine: 305 TBI
thanks for finding that!
Old Apr 24, 2006 | 08:35 PM
Car: 89 camaro rs
Engine: 305 tbi
glad to help. let us know if that fixes 'er.
Old Apr 24, 2006 | 09:40 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Just make sure not to get any carb cleaner in the IAC itself. One thing to be really careful of when cleaning is not to wash the grease out of the bearing assembly that supports the rear of the IAC stepper motor, or itll stick.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 9, 2015 10:01 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
