general tbi
Car: 1989 camaro
Engine: 350 chevy tbi
Transmission: 350 lock up shorttail
general tbi
are the heads on a 350 tbi different from the heads on a older 350 chevy and can i use older heads on a tbi 350.
Car: 1983 G20 Chevy
Transmission: 4L60
Switching from TBI heads to anything else will require more fuel and more timing.
TBI heads like 28-30* of total advance and others are typically 34-36*. That means bump the distributer timing up to around 4-6* BTDC.
I would recomeend getting an adjustable fuel pressure regulator as well. The fuel curve will not be linear so you will have to sacrifice low rpm vs high rpm fueling. It is fun to achieve the balance and even then it is a comprimise.
That brings me to my next point, the above are temporary band-aids to DIY chip burning.
I KNOW we have many places in the area to source a good set of swirl ports, why change.
Car: 1983 G20 Chevy
Transmission: 4L60
thanx i guess ill leave well enough alone
Pac J
May 17, 2020 10:44 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
