Advancing Timing
Old Apr 29, 2006 | 03:27 PM
kazer's Avatar
Advancing Timing
Until I get the EBL and some kind of chip tuning stuff, I've just been doing basic things to my L03. In the sticky about usual tbi mods it mentions adjusting base timing, but not anything about a good safe place to put it. I have 93 octane gas here (good ole east coast) and am wondering if advancing it 4 degrees or so would be beneficial.
Old Apr 29, 2006 | 03:33 PM
87blownnosiroc's Avatar
yes as long as it dont ping
Old Apr 29, 2006 | 03:37 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
My engine is TPI with L98 cam,, east coast exxon 93 octane.. 15* base timing.. 8-12 degrees should be fine, just listen to the engine... 8 degrees is safe as hell.
Old Apr 29, 2006 | 03:40 PM
kazer's Avatar
Any ideas what kind of gain can be had by just advancing the timing? Yes I do know to listen for ping, and know what it sounds like (buddies coronet needs tuned). Any guesses on where optimal power will be? Should be similar between stock engines (though obviously not identical).
Old Apr 29, 2006 | 04:18 PM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
my car loves it at 4 but my buddies RS loves it at 8, so its just basically set it, drive it, and adjust
Old Apr 29, 2006 | 05:44 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
For non swirl port (fast burn) heads this is normal. Swirl port heads by design do not need a lot of inital (and or total) timing. 0° to 4° base is all you need. Most 300+ hp swirl port headed combos will need only 28° of total timing. This was a key design feature for these heads (economy, torque, and emissions).
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
