CAM specs??
Old May 5, 2006 | 11:11 AM
SAMRS350's Avatar
Car: 1989 Camaro RS
Engine: TBI 350 - Approx 300hp
Transmission: 700R4 (Soon to be Built)
Axle/Gears: 3.73's & Eaton Posi
CAM specs??
I just swapped out my 305 to a 350 on a 89 TBI camaro. IT idols rough and i am having trouble finding a sweet spot in the timing. It has a melling CCS2 cam in the engine. Flat tappet. I was wondering if anybody can help me find the specs of that cam. it idols exceptionally high and strugles to stay running when in gear and not moving.like i said i cant find the sweet spot in the timing. any help From those TBI masters on here?????
Old May 5, 2006 | 11:57 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
What are the cam specs?
Old May 5, 2006 | 12:39 PM
Ronny's Avatar
what do the datalogs look like? did you burn a chip?
Old May 5, 2006 | 04:58 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Maybe finding an L05 chip, or computer and chip would be a good start going from 305 to 350. May run better but not optimum depending on cam.
Old May 5, 2006 | 05:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Apparently that cam is a stock truck replacement cam ('69 through '95). I found it on some web-site that sells Melling cams (search +Melling +cam +"CCS-2"). What did you use for the TBI unit? If it is still the stock 305 unit then you need to either increase the fuel pressure or replace the injectors with larger ones. Can then get into chip tuning, or use a 350 chip and hope for the best.
RBob.
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
ericjon262
Sep 11, 2015 06:07 PM
angel2794
Sep 8, 2015 06:22 PM
Formula_88AE
Sep 3, 2015 01:47 PM
