Help with TBI Computer
Old May 10, 2006 | 04:33 PM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
I switched my 83 crossfire to a TBI set up i ran one week on the crossfire computer and now im switching to tbi computer. My questions this. I have the pin out from both computers. and looking at the two different computers there are a couple wires of concern. 91 has input from the tranny. on my 83 there are no tranny sensors. for fuel injection theres only a single ground. there are some other wires also but i think ill put them on a switch. for the ram air vents is there a pin to put those on so they activate at 3500 rpm or so.
Bottom line will the computer swap work. I'll take any thoughts I can get.
Old May 11, 2006 | 11:07 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
It should work fine. The input from the trans is the 4->3 downshift thats used in the TCC logic. Search around, im pretty sure this has been done before.
Old May 12, 2006 | 07:15 AM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
thanks
I found what i needed the shop manuels my roommate has access to, pinout diagrams and such
Old May 15, 2006 | 06:55 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I have a TBI computer sitting here. I replaced mine thinking that it was at fault. However I was wrong, so now I have 2 TBI computers. PM me if you need one.
Other than that good luck.
92firebirdguy
Sep 1, 2016 07:53 AM
BLK87Z
Sep 18, 2015 11:29 PM
89bird2.8
Sep 18, 2015 07:46 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
