Surging under WOT
Old May 11, 2006 | 08:25 PM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
Surging under WOT
Friend has a 88 L05 and we just adjusted the timing on it because he recently got his distributor rebuilt, we went for a test drive and I told him to mash it (he normally doesn't so this problem might have been around a while) it started surging. I then asked him if he remembered to hook up the EST wire which he didn't so we pulled over and hooked it up without restarting (does it make a difference?) Tried it again and same surging at WOT. Anyone have a cure?
Old May 11, 2006 | 08:46 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The EST connector makes a difference. You need to pull the ECM B fuse to reset the code in the ECM. Sometimes simply cycling the key will make it go off as well.
Fuel Filter?
Old May 11, 2006 | 10:47 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Surging WOT
Mine did the same thing. Was a TPI though ended up being the EGR valve.
Old May 11, 2006 | 11:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You need to shut down before reconnecting the EST in order for the ECM to reset to normal operation.
Old May 11, 2006 | 11:17 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
We recently replaced the EGR about a week ago actually.
I'll have him try it tomorrow since it will hopefully be reset being shut off.
Fuel filter is fresh, though we're going to disconnect the lines this weekend, blow them out with compressed air and then replace the filter again.
junior419
Apr 7, 2025 11:35 AM
Pac J
May 17, 2020 10:44 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Damon
Sep 26, 2015 04:29 PM
banksGTA
Sep 13, 2015 11:56 AM
