Can I change linkages between throttle bodies?
Old Sep 28, 2005 | 07:55 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Just curious as to whether this is thesible or not? I just want to change out the throttle linkage, everything else on my throttle body is fine.
Old Oct 1, 2005 | 03:24 PM
Car: 91 RS
Engine: 350 TBI
Nobody knows?
Old May 11, 2006 | 07:53 PM
Rage789's Avatar
Car: '85 El Camino SS
Transmission: Turbo2
Last time I needed something done on my Throttlebody I just pulled one out of a junkyard that wasn't busted. You can find them everywhere since the general put throttlebodies (for a while) in just about every sbc van, full size car, truck, and of course our own beloved 3rd gens. Nice to see someone else sticking with the TBI setup, its freakin amazing how much power they'll put out when you play with them. I take it you've watched Heartbreak ridge a few times lol. Marines kick ***.
Old May 11, 2006 | 08:15 PM
Car: 91 RS
Engine: 350 TBI
I'm also a Marine.
. . . and yes, we do.
Old May 12, 2006 | 09:07 AM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
yes it can be done you hav two way to do it first is to just cut the end off and weld it on second way is to grind the spot weld off the bottom of the throttle plate screws so you can unscrew them and take off the throttle plates and remove the one screw at the end of the throttle shaft and transfer to the other tbi unit.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
