Will 350 LS1 heads fit on a 305 TBI?
Old May 15, 2006 | 05:21 PM
89 Camaro RS V8's Avatar
Car: 1984 Z28
Engine: 350 Carb
Transmission: 5 speed manual
I have a 1989 Chevy Camaro with a 305 TBI engine. I also have a heads off a early 90's corvette LS1 and wanted to know if they would fit on my 89 305 Tbi.
Old May 15, 2006 | 06:07 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
LS1 heads will not fit, LT1 heads will not fit.
You might want to figure out what you ahve, the LS1/LS6 didn't not start production until '97 in the vettes. from 92-96 there could have been an LT1/LT4.
If they are from pre '92, then they are likely L98 Alum heads. If that is the case, they will fit.
Old May 15, 2006 | 06:47 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
LS1 is not a 350.
(I think its like 347 or 346 sumtin like that, and its bore is actually smaller than 350's ar around 3.86 or so.) (Not exactly sure on exact numbers though).
Everything else what Dewy said!
(Usless post I know, but I had to )
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
