LT-1 cam specs
Old May 24, 2006 | 11:15 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
LT-1 cam specs
I havent been getting much feedback on the tpi with stuff but i figured this board would have more usefull info on the lt1 cam. I have a pretty much stock 89 tpi 350 only major mods is full exhaust from slp. I was thinking about aluminum l98 heads how much better are these then stock iron heads? Also will they raise my compression? Well for the main thing i wanted to know what are specs on a 93-97 lt1 cam i kno there different throught the year but which lt-1 cam should i look for getting in my tpi. What is the intake and exhaust duration, valve lift, lope seperation, rpm range on my stock l98 and on a lt-1 cam. Any help is greatly appreciated.
Old May 24, 2006 | 12:03 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
The alum. L98 heads will raise your compress, but they are also alum. You shouldn't have any issues there. Considering the vette's came stock with your bottom end, and the alum. heads.
I would go with a little more than that LT1 cam for a 350, the L98 cam, is actualy pretty similar spec wise to the LT1 cam. I would put something just a hair warmer in a 350, if I was going to go thru the trouble of a cam swap. If you are sticking with TPI, I wouls shoot for something in the 212-216* duration range.
If you are going with a HSR or aftermarket intake, Then go for something like the Hot-Cam, that would be a nice fit in a motor with some mildly ported L98 heads, and a HSR.
Old May 24, 2006 | 08:37 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
cam specs
Anybody got the specs on the lt-1 cam? I kno I can go bigger but i dont wanna pay 300 for a cam when i can get a lt-1 cam for hardly nothing. Also i dont want a huge cam that is gonna ruin my heads or mess up my computer.
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
ericjon262
Sep 11, 2015 06:07 PM
angel2794
Sep 8, 2015 06:22 PM
Formula_88AE
Sep 3, 2015 01:47 PM
