GOIGN FROM 305TBI-350CARB'D IN A 91 GAUGES? SNESORS?
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
im planing on switching out my 305tbi to a 350 carbed. its a 91 camaro so it has the newer style gauge cluster. i want all my gauges to work liek they do now.just with the bigger engine. would it be easier to just find a cheap camaro around with a bad carbed engine or is it easy enough to do it on mine? any input would be appreciated thanx
Car: 1985 project SC
Engine: LSX (planning stages)
Transmission: (planning stages)
Axle/Gears: (planning stages)
you will need to get a mechanical speedo becouse the 90-92 use the VSS signal to the ecm and i belive the tac needs to be changed to i cant remember right off hand id have to look it up
Car: 1983 G20 Chevy
Transmission: 4L60
For the other gauges, just re-use your existing sending units for the Temp/Oil pressure gauges. The wiring will go into the main harness, not the TBI harness. It will be much simpler to seperate out the TBI harness from the engine harness, and then eliminate what is needed. Don't cut everything, then try to go back.
Why not keep the TBI setup and put it onto the carb engine with a carb-TBI adapter. See the picture below.
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
im undergoing the same thing in a few weeks with my 91 firebird and i would really hate to fire up my engine and find that my guages dont work has anyone actually done a carb 350 swap on a thirdgen with electronic guages?
