Need help with fuel lines
Old Jun 8, 2006 | 12:00 AM
ffvetteman's Avatar
Heres the deal. Im putting a TBI 350 from a 1989 Camaro in my 1986 Trans Am that was a 305 carb. I need all new feul lines from the tank up.
I go the tank out of the Camaro with the sending unit up to the rubber lines. The long steel lines from the back of the car to the front were rusty and no good so I left them in the car.
Now Im getting close to needing the lines front to back. I wanted to put in stainless steel lines. Up front I have the steel lines on the TBI unit, but not the rubber.
Now my problem is where should I buy the lines, and what exactly do I need? It appears that I need the rubber lines from the sending unit on the tank to the main lines. and the rubber lines from the main lines to the TBI lines in the front. I also need the fuel filter and the main lines front to back.
Is that correct? Also I need some good vendors. I could not find them on Hawks.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
