Cheapest LO3 275ish HP setup
Old Jun 16, 2006 | 12:15 AM
  #51
KniteWulfe's Avatar
Car: 91 Firebird, (miss my 87 Formula)
Engine: LO3
Originally Posted by Casey_Butt
It isn't so much as how much flow you need to support the cam, but how much will allow the maximum output that the entire setup is capable of.
Originally Posted by me
to reach the flow i need and support that size of cam
Well, you answered the 1st part of my question very well, and thank you. My wording was a bit vague on the second part though. I didn't exactly mean how much flow to support that cam but what heads will support that cam, in other words will the stock springs handle that lift?
Old Jun 16, 2006 | 01:46 AM
  #52
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Originally Posted by Dewey316
Am I missing something about the brokeback mountain thing?
Brokeback Mountain is a movie about two gay cowboys. Didn't do that well at the box office here in Oklahoma.
Old Jun 16, 2006 | 07:40 AM
  #53
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Originally Posted by GodOverYou
[FONT=Arial].....
In an exhaust pipe you have atmosphere and exhaust gases. As the exhaust gases cool, they have two choices, spread (expand) or condense. Spreading of the molecules (expanding) requires less energy.
And I suppose you've had at least one course in Thermodynamics to support the above statement? Heat transfer from the exhaust to the exterior (via conduction and then convection) will occur. The ideal gas law shows that a decrease in temperature will result in a decrease in the product of P and V, within the confines of the control volume used for the analysis. How much P or V or both decrease depends on entropy. Explain the change in entropy where expansion "requires less energy" (your words).
Now I'm going to go a little bit out of my realm, ...
I think you already accomplished that. This would be your 2nd time.
.... but in the audio design world, we often talk about dust and air pollutants affecting air movement, so I will make what I consider a reasonable assumption. Since we are now going down to a molecular level, there are heavier molecules and lighter molecules. As the gases move, the lighter molecules simply don't have the force to constantly move the heavier ones and eventually lose a lot kinetic energy, but by giving them more space to move, they will move out of the pipe more effectively without causing the impairment of the movement of heavier molecules. What you ultimately achieve is the faster movement of the gases as a whole by allowing them a greater space to exit through.
I didn't know that people from the audio design world know anything about the kinetic theory of gases. I also didn't know that lighter molecules don't have the force that heavier molecules had. I wonder how this would change the mixture model of gases at thermal equilibrium where the molecules would have had ample time to spread the kinetic energy around. And I didn't know, furthermore, that dust is important in any of these discussions.
However, if you force them to condense - costing more energy than expanding into and through the atmosphere - they will exit more slowly than if let flow at a LESS restricted rate.
There are ample sources on the web that explain thermodynamics as applied to gases, and going past those fundamentals, there's open courseware on engine technology. I won't do your homework for you in finding them, but I do suggest you find them and read them.
Old Jun 16, 2006 | 09:04 AM
  #54
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I was curious about that too.
Old Jun 16, 2006 | 09:08 AM
  #55
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Yeah, and I am trying to figure out what I have to do with that. I assume you are just trying to call me gay, I can't figure out why you felt the need to insult me in your reply.
Old Jun 16, 2006 | 09:19 AM
  #56
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I don't think he meant anything personal about it. Just that we are old as dirt members and he was jokingly trying to make a point. But then again I don't know.
Old Jun 16, 2006 | 09:30 AM
  #57
Casey Butt's Avatar
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
An LT1 cam is pushing the limits of the stock springs, even if they can handle the lift I doubt that they'd have the spring pressure to control the valves at higher rpms. Plus, your old springs will be fatigued from years of use. Springs are relatively cheap so you'd be MUCH better off getting some new ones ...with higher pressures and rate than the originals (which are inadequate). Go for something with a seat pressure of around 85-100 lbs (@ 1.700") and open pressure of 250-310 lbs (@ ~1.200").
Old Jun 16, 2006 | 09:35 AM
  #58
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
IIRC, the specs on the springs I use are 110 @ 1.700" and 290 @ 1.200" with .510 max lift. I am putting LT4 springs/retainers on everything I am building now.
Old Jun 16, 2006 | 10:34 AM
  #59
Dewey316's Avatar
Car: 1990 Camaro RS
I am also running the LT4 springs. If you are going to all the trouble of cam swap, take the extra few minutes, and put in new valve springs.
Old Jun 16, 2006 | 12:33 PM
  #60
KniteWulfe's Avatar
Engine: LO3
Cool thanks once again for the input guys.
Another thing I was wondering was about was seanof30306 mentioned something about 64cc's dropping my compression too low. I think the heads I was planning on using are 64cc heads too. What would they need to be milled to to maintain around 9.5:1 or maybe up it to 10?
Old Jun 16, 2006 | 01:55 PM
  #61
DM91RS's Avatar
Car: 91 RS
Originally Posted by BMmonteSS
You guys lost me......I was simply applauding the smackdown administered by Sean.....No brokebackness implied
I agree with this statement. I don't believe Sean meant anything derogative to either. Just stating someone who is very new starting arguments in almost every thread involved and comes in here debating with members with experience not bullsh!ting.
Also thanks to kdrolt.
Back to reality and the poor guys thread.
KniteWulfe I have had the standard GM Vortecs installed on my 305 for 5 years. No milling. I think the compression loss in overrated. Who knows what the Vortecs actually cc at without checking themselves as I read early on that GM stated that most of the castings were around 61cc. So take that for what it's worth but they run pretty good as is. I bought them for a 350 and they will end up back on a 350. I would not mill them.
My 2cents.
Old Jun 16, 2006 | 03:33 PM
  #62
KniteWulfe's Avatar
Engine: LO3
Hey who you callin poor?
Well I wasnt referring to the vortecs, my friend has some heads from his truck that I will probably use and he thinks they might be 416s or 601s. He still has to check the casting. He said he was pretty sure they were 64cc though.
Old Jun 16, 2006 | 03:47 PM
  #63
Casey Butt's Avatar
416s have the same "open" style combustion chamber as the 081s and 187s. They're about 58cc. 601s have a much smaller "closed" style combustion chamber because they were originally cast for the 267 engines of the 1970s ...most people say they're 53cc. I haven't cc'ed them myself, but I have a set on my table next to 58cc 187s and I guarantee that they have significantly smaller combustion chambers ...53cc actually seems large for them.
Old Jun 16, 2006 | 03:48 PM
  #64
Engine: L03 305 TBI
Dude, I was just kidding. No offense intended. Please accept my apology. What DVDs you watch over and over and over and over and over and over are totally your business.
Old Jun 16, 2006 | 03:56 PM
  #65
Engine: L03 305 TBI
My 2cents.
I helped a buddy cc a set of SDPC Vortecs, they came in at 63cc.
The CHP Mission 305 Vortecs were milled .060, which is .030 more than I've been told they should be milled by a head rebuilder I've done a lot of business with and trust. He said they're prone to cracking as it is, and milling them makes them even more so.
The Mission 305 article listed the compression at anywhere from 9.5:1 to 10.5:1 after the milled Vortecs were installed (with the thinnest head gasket available). They were attempting to calculate the compression mathmatically, though, they never actually measured it; I'd be a little leery of their results. This is the same guy who RAVED about how well the car drove without any chip tuning until someone from here called him out on it. In the next article, he admitted it actually drove like a pig until they got the new chip.
Old Jun 23, 2006 | 03:31 AM
  #66
czbigboy's Avatar
Car: 85 IROC Z
heads
Back to the heads. You would also need to watch for chamber size. You dont want to lose compression from to big of chambers. You will need to stay around the 58cc to keep your compression up.
Old Jun 24, 2006 | 08:20 AM
  #67
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
If my memory serves me correctly I think the general rule of thumb is 3% power for every point of compression. So droping a half a point is around 4.5HP on a 300 HP motor......totally not worth worrying about. With gas prices now 87 octane looks very apetizing.
Old Jun 24, 2006 | 01:41 PM
  #68
KniteWulfe's Avatar
Engine: LO3
Ok, so then how many CC's make up a point of compression?
I agree about the 87 octane. That seems like alot less than I expected, but the desktop dyno gave about that result too. I could probably figure that out with the software but I'm still learning how to use it.
Old Jun 24, 2006 | 07:13 PM
  #69
DM91RS's Avatar
Car: 91 RS
My thoughts exactly............and I have run only 87 for years.
Old Jun 29, 2006 | 01:22 AM
  #70
Rossi's Avatar
Car: '92 Camaro RS
Engine: LO3
[quote=DrummerDad]I was a stock L03 auto, running 2.73s, at 1400+ feet. 16.8 is actually good. At sea level it would be a little better. Its not uncommon for LS1 powered f-bodies to run 14.0s here. With a little work a few have broke into the 13s, with the 6 speed.
Not saying thats bad, but ive seen Stock LS1 powered f-bodies running high 13s very regularly at my track. Im at sea level too.
Old Jun 29, 2006 | 01:29 AM
  #71
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
[QUOTE=Rossi]
My track is 600' above sea level where my TBI 350 will run 16.08s @ 86ish.
Old Jun 30, 2006 | 05:39 AM
  #72
DrummerDad's Avatar
Car: 1991 pontiac Firebird
Engine: 305 tbi, Lo3 (for now)
Transmission: auto
Axle/Gears: stock (for now)
[QUOTE=Rossi]
Thats what I was saying. We are 1475 feet above sea level. An LS1, 6-speed here on average, runs about a 14.0, maybe a 13.8, if theyre lucky. At sea level, it could be as good as a 13.5.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
88CamZ
Oct 8, 2015 10:29 AM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
