Manifold suggestions?
Old Jun 26, 2006 | 09:39 PM
6SPEEDEMON's Avatar
Car: 1988 IROC-Z
Engine: 305 tbi
Transmission: t56
What is the best manifold for a Tbi car with mild mods?
Old Jun 26, 2006 | 10:02 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
You're best bet would be the button, you'll get quite a few different perspectives from many...
Old Jun 27, 2006 | 10:07 AM
Casey Butt's Avatar
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
With mild mods I'd go with an aftermarket dual-plane design. Some people get single-planes to work well with TBI, but your typical aftermarket dual-plane will flow well to 6000 RPM on a 305 (remember the idle-5500 RPM range they advertise is for a 350). The dual-plane will keep nice low-end torque and throttle repsonse and also allow your car to breathe well up to the safe operating limits of your crankshaft, main bearing caps, etc, so I don't see a reason to go with anything else for your application. Also, your heads will have small cross-sectional runners, so a single-plane manifold would be a little mismatched. Single-planes seem to work better at low-RPM with TBI than with carbs, but it's simply a case of necessity and application here ...you don't need a single-plane for your application and a dual-plane would be more appropriate for what you're trying to achieve.
Mildly modded L03 ==> dual-plane manifold.
Old Jun 28, 2006 | 08:38 PM
6SPEEDEMON's Avatar
Car: 1988 IROC-Z
Engine: 305 tbi
Transmission: t56
thanks! im now looking at the edelbrock Performer Tbi... Its a dual plane, and with my "ultimate" tbi mods, I hope to notice atleast some gain...I have an Lt1 cam i would like to swap in but im alliterate when it comes to prom tuning so I need to do some reasearch first... Thanks Alot guys!
Old Jun 28, 2006 | 08:54 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
you could also get a carb intake and then get the tbi adapter. you would have a lot more choices to choose from, and some are cheaper then buying a tbi intake.
Old Jun 29, 2006 | 01:38 PM
Casey Butt's Avatar
I did the open element and something similar to "Ultimate TBI" mods a few years ago. I had no other mods at the time. I did notice a distinct improvement in the car's ability to pick up the RPM. The difference wasn't earth-shattering or anything, but I do remember that the car felt distinctly less restricted as the RPM climbed.
Incidently, even that "small" change threw the PROM off a little. It wasn't severe or anything, but I did "massage" the VE table gently to get the numbers back on. I could have gotten by without doing that, but it just shows you how sensitive the ECM is.
If you change the intake manifold and do the Ultimate TBI mods I think you'll definitely notice that the car "breathes" better as the RPM climb (but will still be restricted if you have the stock exhaust). It's a good place to start learning to tune the PROM because the tables will be off a little, but not too much, and it should be easy to get things "on" again.
Old Jun 29, 2006 | 09:24 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Seek, and ye shall find
86CamaroDan
Sep 29, 2015 10:08 PM
R13_Braz
Sep 18, 2015 05:00 PM
Rally Smith
Sep 14, 2015 06:59 PM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
