Just barely failed smog test (Ideas)
Car: 1988 Vette
Engine: 383,AFR,MiniRam
Transmission: ZF6spd
My HC's moved just outside passing when the truck shifted gears and went into 3rd during the loaded dyno emission test at 25mph. I'm wondering whats the easiest way to geta pass? Should I try and lean it a little more in 3rd w/light load? Play with timming? Fuel pressure?
Kelvin
http://www.jaybquick.com/_Kelvin_Upload/Smog Test-1.tif
Setup:355,10.1,CNC TF 195's,Ported Edelbrock manifold,46mmT-body,75#inj's,219@.050 .520 HR etc....
Kelvin
Car: 1983 G20 Chevy
Transmission: 4L60
You said this is in a truck? What is your setup on it? I had a real mild setup when I last had mine on the emissions rollers. Make sure that you have a good cat and it is up to temperature before you test. I have also seen Bosch NB 02 sensors cause emission failures.
Why are you going into 3rd @ 25 MPH, I keep them in 2nd out of personal preference when I inspect them down here. I have an 1,100-2,500 window and have found that alot of them will fail when you run it down near the bottom of the rpm and they become cleaner as the RPMs rise. 25 MPH is pretty early for 3rd, especially if your truck has say 3.08 gears like alot of them do. What ends up happening is the dyno puts more load on your engine than say driving 25 MPH in the city would do and puts you into places on the VE table that your engine would likely rarely see.
Car: 1988 Vette
You're right, it must have been the shift to second. And this is my 1990 K5 with 3.73 gears. The CAT is new OEM piece and it was pretty much up to temp. I heard my electric kick on so 195'ish is my guess. The O2 is AC Delco as well.
I agree with you on the RPM lowering the results. But it's up to the tech I guess to run it on the upper end vs lower. So the normal rpm window is as you indicated? Cause I can see on the printout that it was tested at 1500ish rpm.
KM
KM
Car: 1983 G20 Chevy
Transmission: 4L60
KM
KM
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
I ran the Pass or don't pay additive in my fuel before I went. I passed then. Just a thought. Dunno if it will help you though.....
92camaroJoe
Aug 13, 2015 06:07 AM
