smoke after bunch'o'mods
Old Jul 10, 2006 | 12:42 AM
1991 RS 305's Avatar
So I did the vortecs, milled to 56cc's with .015 shim gaskets. New springs and seals on the heads, lt1 cam, performed air gap intake, ultimate TBi mods, hooker headers, cat delete. Car runs fantastic, but I get a puff of bluish smoke every now and again when i start it. No oil in coolant or coolant in oil. Could I have a bad valve seal, even though they are new? any ideas as to why it does this, only on start up? NEVER did this prior to mods, and it started immediately after mods. engine appeared to be in good shape, cross hatches in all cylinders still, no ridge at the top of the cylinders. Any ideas?
Thanks, Matt
Old Jul 10, 2006 | 07:42 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Valve guides?
Old Jul 10, 2006 | 07:50 PM
91RedFirebird's Avatar
Car: 91 firebird
Transmission: t-56
sounds like you need to do alot of tuning. Still running the stock chip?
Old Jul 10, 2006 | 08:53 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What type of valve seals did you go with? Were the guides cut on any of the heads before you installed the seals?
Old Jul 11, 2006 | 12:03 AM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
When i first bought my car it smoked a little on startup. Then i removed the AIR system now its like theres little elves hotboxing my catback and all the smoke comes out when I start her up. Its all good after that though...
Old Jul 11, 2006 | 01:36 AM
Stock tune, bumped fuel pressure and ported TB. I know the car has lots more potential, but it's driveability is actually great. When the engine is cold I can make it bog, somewhat due to the air gap.
As far as brand of seals, not sure. I took the heads to a local reputable machine shop. The advised me to a few things, so I'm sure if the guides were worn they would have tried to sell me new ones. Is seals or guides what i'm probably lookin at here? All emission crap is gone, not that this would make a big difference at start up.
Thanks again, Matt
FormulasOnly
Jul 23, 2018 08:47 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
