whining, sounds like a super charger.
Old Jul 11, 2006 | 03:32 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i have a 305 tbi. ok i just replaced my intake with a weiand hi-rise "7546" then used any adapter so i can put my tbi on it. got it all back togetherand now i have this high pitched whining noise. it gets louder as rpm's go up. maybe a vacuum leak? how would i find this by using the carb cleaner method. oh and i know the tachs in these cars are bad, but it says that it idles at 25-3000 rpm. it does idle really high.
Old Jul 11, 2006 | 03:41 PM
92IrocRS's Avatar
Car: '92 RS ~ '92 Ranger
Engine: 305 TPI ~ 2.3 OHC
Transmission: 700R4 ~ Mazda 5-Speed
Axle/Gears: 10-bolt 3.23's ~ 7.5
Check to see how much power your getting out of the alternator...
Old Jul 11, 2006 | 04:30 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
sounds to me like a vaccum leak. You could do the carb spray or you could just listen and find the vaccum leak. chances are its by the trottle body gasket just listen to it and put your finger around the base of it till the noise changes. Did you clean the base of the thottle body before mounting it and did you use a new gasket?
Old Jul 11, 2006 | 08:13 PM
alt is new, and the surface was clean. how do i do the carb spray? just spray it at the base or what?
Old Jul 11, 2006 | 08:32 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did you make sure to set the timing correctly after the intake install? Check and make sure that all vacuum lines are connected as well as your throttle cable. Make sure that the throttle cable is mounted correctly and that it is not set to far backing causing it to open the throttle.
Old Jul 11, 2006 | 08:44 PM
the timing is set at 0* all lines are connected, butterfly's are level.
db057
Jan 10, 2020 08:55 PM
Grant2k
Apr 4, 2016 08:21 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Youngs92
Sep 23, 2015 11:29 AM
Blue419
Sep 10, 2015 01:03 PM
