heater diverter valve
Old Jul 14, 2006 | 01:56 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
dont delete heater diverter valve
instead of deleating it why dont we just reroute it behind the strut tower by the blower motor fan lots of unused space there .
i figured that since most all gm cars have the diverter valve some where it must be a needed thing .
so i just relocated it and now its only the smog set up in the way of my valve cover
heard to many people blowing the heater cores when deleteing the valve and being that the heater core is a pita to change .
moveing the valve is a much better idea
Attached Thumbnails heater diverter valve-img_0363.jpg   heater diverter valve-img_0364.jpg   heater diverter valve-img_0365.jpg
Old Jul 14, 2006 | 02:03 AM
Car: 1991 camaro RS
had 2 more pics that help show how to do it
you have to disconnect the valve then run the hoses under and inbetween the ac and the heater box
the front hose runs inbetween the ac tube and the ac line and just run the vac hose over top the heater fan box "my vac hose is 3" shorter so mine has some tension but any one else that dose this will have no problems doing this
gm should have done this in from the factory as this looks much better to me
i also didnt want to remove the valve as i happen to like cold ac
Attached Thumbnails heater diverter valve-img_0366.jpg   heater diverter valve-img_0367.jpg
Old Oct 4, 2010 | 11:25 PM
1991Camaroz28's Avatar
Car: 91 Z28
Transmission: TH700-R4
Re: heater diverter valve
Nice. i have been thinking of doing something kinda like that on mine, now that i finally replaced my heater core.
Old Oct 4, 2010 | 11:27 PM
Car: 1991 camaro RS
when i upgraded to tpi i had to move it once again but its still not blocking the veiw of the engine
Bubbajones_ya
Jul 6, 2024 08:32 PM
drptop70ss
Oct 4, 2015 09:44 PM
Formula8r89
Sep 22, 2015 04:24 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
