why is it chugging!!!!! HELP!!!!!!!
Old Jul 19, 2006 | 09:59 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
my 89 TBI is chugging and missfiring when i start it up for the first 5 minutes maybe 10 minutes but it keeps getting worse, after it runs awhile it will be fine i dont know what the problem is...its has a little over a 100K someone please help me get this fixed!! thanks!
Old Jul 19, 2006 | 10:38 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
sounds like oxygen sensor making engine run rich
also check if your getting a code from the ECM
Last edited by FireBirdKnight; Jul 19, 2006 at 10:40 PM. Reason: Automerged Doublepost
Old Jul 19, 2006 | 10:53 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Sounds like the O2 may be whats keeping it running acceptably when it warms up. Could be alot of things. Faulty fuel pump, CTS, MAP... Id take a look at the fuel pump pressure and CTS first. Those are the most likely.
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
sorry im kinda of a noobie where could i find that and how could i fix it
Old Jul 21, 2006 | 01:27 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
can you please tell me what the CTS and MAP are....the car keeps getting worse and worse was gonna go to town with it today started it and it did its normal chugging and missfiring kept it at 2000RPM constant and it would fluctuate about 200-300 rpm i messed with it for about 10 minutes and said screw it, it really pisses me off and i dont know what to do
Old Jul 21, 2006 | 02:25 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Sounds like you are dealing with something similar to Bruce's problem. Fuel issue, check your injector spray pattern, when was the last time you changed your fuel filter and run some injector cleaner after changing it. Still doing it... check fuel pressure... hook up a diagnostics tool.
Old Jul 21, 2006 | 10:40 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
the fuel filter is brand new and i put injector cleaner and it didnt do any good at all i tried that when it first started doing it
Old Jul 21, 2006 | 11:58 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
check the voltage on your TPS (throttle posistion sensor) with a voltmeter or digital multimeter.
i think the *magic* voltage is 5.55
Also, pick up a Haynes and/or Chilton's manual from your local auto store. they may be able to help you with your problem as well.
bonz
Nov 2, 2003 11:43 AM
grafx
Aug 23, 2003 12:31 AM
firebirdkid
Jul 13, 2003 10:29 PM
IROCThe5.7L
Aug 7, 2002 01:03 PM
Dan87IROC-Z
Mar 12, 2001 12:25 PM
