help please, cars runnin bad
Old Jul 20, 2006 | 11:53 AM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
hey i have a 91 l03 t-5 camaro, its bucking and hesitatiing very badly, and its idling very harshly......
1. i think it could be bad gas, but i put 2 bottles of water remover in, problem continues
2. could it be the cat?
3. could it be the IAC sensor?
4. any ideas? please help....
Old Jul 20, 2006 | 04:55 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
does it feel like it's running lean, do you have a check engine light on?
I'd probably reccomend checking the fuel pressure at the tb, most likely a worn out pump.
might replace the fuel filter that can't hurt you any, it's near your rear subframe in front of the rearend on the driverside.
Old Jul 20, 2006 | 06:06 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
fuel pressure is great, computer is fine, brand new alt and battery (great voltage), no SES light maybe a sensor? tps? someone said maybe a fuel pump relay, does that sound right?? thanks sooo much for the help.... please respond soon... this is urgent
Example.....
turn key, about 4-5 seconds to start, runs for maybe 2-5 seconds, then its off... if i keep giving it gas it will run (VERY badly) but it will run... please help guys, i need this car to get to work and i am very broke at the moment.... i REALLY appreciate it
Old Jul 20, 2006 | 11:19 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Check and makesure the plugs to your injectors are fully connected and no wires have come loose. I know that happened to me and my car ran like poop.
Old Jul 21, 2006 | 06:39 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Are you watching the FP the whole time it's doing this? Even an almost dead pump will bring the system up to pressure when the motor isn't running. Then once the motor gets running it can't keep up and dies out quickly. Sure sounds like a fuel issue to me.
Old Jul 21, 2006 | 11:50 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
just my luck, i just bought this car 3 days ago..... and now i have to perform one of the hardest tasks there is.... wonderful
Old Jul 21, 2006 | 01:10 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
would a bad full pump be able to deliver enough full at WOT to make the motor rev high? because once im down struggling with 1st gear, it will drive (very irraticly).... im leaning more toward the water in the gas theory? anyone else agree?
Old Jul 21, 2006 | 01:59 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I think we need a bit more information if possible...my car has acted like that at least 5 or 6 times in the last few months and each time its been something different. I put in wrong size (V6) injectors, I had a plug on one injector not fully connected, I had a CTS go bad, etc etc. Although that does sound most like the problem I had when one injector plug wasn't plugged in. I was kicking myself for that one until my dad (who isn't even familiar with TBI) walked over and said "Whats this?", pushed the injector plug back on, and boom.
What are the injectors doing? Are they firing like normal? Did you check your wires and make sure they're all plugged in?
Old Jul 23, 2006 | 04:42 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
well i really dont think its the ignition wires.... they all checked out.... the TBI sprays VERY hard at WOT soo i dont think its the pump... and the filter is brand new as well.... im leaning towrd water int he gas or a sensor, i just replaced the FP relay, the TPS, swapped computers, new alt, new batt, new wires, plugs, cap, rotor, oil + filter, air filter, fuel filter.... etc....does that help?? Also what is the easiest way to drain a gas tank? and does anyone have a link to that fuel pump replacement thread?
THANKS A TON!!!!!
Old Jul 30, 2006 | 02:54 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
just thought id finish the thread and let everyone no that was helping me that the problem was the little hose that connects to the FP inside the tank had worn i hole in it some how over time and it just so happens it finally failed as soon as i bought it lol go figure..... once again thanks to everyone that helped!
Frozer!!!
Jan 19, 2024 04:55 PM
86IROC112
Apr 9, 2016 10:20 PM
B_Dubya
Aug 26, 2015 05:09 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
