VAPFR
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
VAPFR
I just got my VAPFR and dont want to mess this up. Where do I pull my vac from off the stock manifold? Im gonna start bolting the body on while I wait for response
PS: No I didnt get any instructions with it.
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
from the manifold....... hehe
Get a T fitting and splice into the MAP sensor vacuum line.
Also, to be completely frank.... you shouldnt be installing a VAFPR if you didnt already know this. It would indicate there is much you dont know about the car, meaning you probably havent done enough to it to need this. What are your other mods. It sounds likely that you dont really need it. Who told you to get one?
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I absolutly wouldn't run with the vacuum hooked up unless I was willing to spend the time to tune around it in the stock code, or use the EBL to properly set it up. Completely unecessary for your stock motor.
I bought it because I got a good deal on it from another member here. I was going to install it because I figured the decrease in idle pressure could help my richness problem on startup. As for not knowing enough yeah I am an ametur with most stuff. I know you pull manifold vacuum from the manifold but I wasnt sure if there was any difference in where you pull it from, therefor I asked for the correct place...
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally Posted by BMmonteSS
I absolutely wouldn't run with the vacuum hooked up unless I was willing to spend the time to tune around it in the stock code, or use the EBL to properly set it up. Completely unnecessary for your stock motor.
Agreed. You can run a vacuum line from the thermac port on the TBI unit. If you run an open element you likely have this port plugged and unused anyway.
