Harmonic Balancer
Old Jul 24, 2006 | 06:28 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Harmonic Balancer
Are there any differences in the harmonic balancers used in small blocks (excluding the externally-balanced dampers for 400 cranks)?
I'm suspecting the balancer on my L03 may be bad. I plan on using a TCI rattler on the internally balanced 383 I eventually plan on putting in, and will simply buy the balancer a little sooner if it'll fit my poor old L03.
Old Jul 24, 2006 | 06:56 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Should work fine, the only differences were that the trucks got the larger 8" damper and the cars got the smaller 6 3/4" damper. Also some older model engines had the timing mark at 2 O'clock while I believe most LO3's had it at 12 O'clock. Might want to double check to see what you have. If you have to look behind the water pump to see the timing indicator then it's the 12 O'clock style.
Functionaly, there is no difference between the different sizes.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
