how do i do an open element??
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
what do i do with the crap that is on the thing to the snorkel ....please help i heard it helps a bit!! thanks
Car: 2001 SS
Engine: bolt on LS1
Could you be more specific? If you are talking about the heat riser to the exhaust manifold I just took off what was attached to the air cleaner and left what was on manifold there.
BTW your sig says go big or go home. So where are you takin the lil 305? lol
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by jak2908
is this gonna be worth it whit just a stock hood?
I made 218 RWHP with IAT readings in the 160*-170* range. I am now seeing IAT readings of 110*-120*. Given that same gain, IF I retested, I should see around 233 RWHP with no other changes. In reality, I would probably see gains of more than that, because of IAT spark compensation which pulls the timing when IAT rise to keep the engine from detonating on the superheated a/f mixture.
PS- I can tell you that it went from reaching 70 MPH on this one ramp, to nearly 80 mph by the end of the same ramp with just the air cleaner/induction change. This light is part of my daily drive and the light is long, with the open element things would be nice and toasty under the hood after idling with the a/c blasting. It was so dogish coming off the light it wasn't even funny. Now it just rips out of the light. Can't wait until it gets into the 60s and 70s here instead of this stupid 105* weather.
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
