Piss Poor Fuel Economy ????
Old Aug 18, 2006 | 10:16 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
**** Poor Fuel Economy ????
Hey fellas,I'm having a consistant problem.
I have a 92 shortbed 4x4,with a 5 speed,3.42 gears and 33" tires.
It originally had a 4.3,I later installed a 305 w/ a Mellings MTC1 cam and flowtech headers,and now it has a stone stock 350,still with the headers.The exhaust is a 3" single,no cat,single in/dual out flowmaster.Every engine has had the ECM/distributor that it left GM with,the 350 is out of a 91 Suburban.I have gotten 9-11 MPG from EVERY engine.I'm not getting any trouble codes,and all tune up stuff(plugs,wires,cap+rotor,fuel filter,etc.) are fresh.
I've had 2 other pickups very similar to this one,one was a 92 with an automatic and identical gears/tires,it averaged 15mpg.The other was a 91 w/ a 5 speed,and 3.73 gears,same tires,it also averaged 15mpg,with a best of 18mpg.so why does this truck use so much fuel?It runs great,just the MPG sucks!
Any thoughts or advice are apreciated!
Old Aug 18, 2006 | 10:20 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Have you used the appropriate ECM/Knock sensor/ESC module/Injector size with every engine?
Old Aug 18, 2006 | 10:24 PM
Irockz's Avatar
Every engine has had it's original ECM,sensors,throttle body and distributor.The only consistant piece is the wiring harness,but I can't think of anything there that could be blamed.
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
djmarch
Aug 19, 2015 12:07 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
