355 TBI Video
Car: 91 RS
Engine: 355
355 TBI Video
Hello, I don't post here often, but I wanted to post the video of the first startup of my 355 TBI. I built this motor and installed it myself, it was the first one i've ever done. and whether you know it or not, I got a lot of help on this project from a lot of you here. Thank you and I hope you like it.
Right Click, Save As
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Car: 1988 Chevy silverado K5
Engine: 350 bored .030, crane cams hyd bluprint l-79 cam 447 lift 272 dur, camel hump heads port and polished 1.94 1.50, afterburner headers and y pipe, holley 670 cfm tbi, holley projection dual plane manifold, accel high pressure fuel pump, 3 inch exhaust
Transmission: 700 r4 with corvette servo and shift kit.
Car: 91 RS
Engine: 355
The cam grind# is CS 268XFI H-13
I'm running a Holley 502-6 with the included injectors. Fuel pressure is stock for the time being until I buy and install a walbro fuel pump.
Pipes are 3" all the way back.
The holley(670 cfm) comes with an adjustable fuel pressure regulator so the fuel pump may or may not be needed. You have to pop out the cap on top of the fuel pressure regulator and then you can adjust it.
codeysabatini
Nov 10, 2015 04:07 PM
Billy Decker
Sep 4, 2015 03:46 PM
