Back to Basics
Old Aug 28, 2006 | 11:34 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Back to Basics
Well, my 1983 G20 has been running a little weird lately (since the head and cam swap) and I finally made time to fix it. It has had some issues that I had not been able to tune out of it. Mainly a hesitation off-idle with the A/C on and a rough, high idle in Park/Neutral with the A/C off. It would also ping off-idle at times. I first removed all the header bolts, 1 at a time, and put in lock washers, tightened the header bolts again, they had loosened slightly allowing O2 into the exhaust stream and was fooling the 02 sensor. I checking the timing, found that it was set at -3* instead of my usual 6*. Still hesitated. I then decided that I had a vacuum leak seeing that my minimum air set screw was all the way out and I was idling with 0 IAC counts. Carb cleaner in hand, I hosed down the manifold and vacuum lines. Bingo, TBI base gasket was leaking between the TBI spacer and TBI unit. Replaced both gaskets, idle dropped immediately. I then set the minimum air screw per GM specs. The idle is now a smooth 500 RPM in Park/Neutral, 550 with the A/C on, and 600 in Drive with the A/C on. The hesitation is gone and hammering the throttle from a dead stop results in good squeal of the tires, instead of a bog.
Here is the cold start this morning, hit the key and it is running. It was taking about 3 cranks to start, prior to this.
YouTube - 350 TBI startup
While I was in there, I cleaned up the harness. Got some 1" wire loom from Napa along with some 1" wiring T's. Some electrical tape and about 1 hr of time cleaned it up nicely.
Before
After
I got un-lazy and made my Accel 300+ race wires and changed to AC Delco Rapidfire plugs from the Champion Truck plugs that I had laying on the shelf when I put the engine in. Champion Truck plugs suck compared to AC Delco Rapidfires.
I also drilled my open element air cleaner base to fit the IAT sensor for the EBL.
Now, about that carpet. Its gotta go
Old Aug 29, 2006 | 06:13 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
glad it was something cheap easy and simple like that.
Old Aug 29, 2006 | 04:07 PM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
I'm jealous I can't for the life of me get my car to crank right up like that. Could it possibly be the fuel pump? That is the only thing I can think of
Jeremys87
Jul 14, 2022 09:08 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
