code 32: 89 rs 305 tbi
Old Sep 18, 2006 | 11:13 PM
19RS92's Avatar
Car: 1992 RS 25th Anniversary
Engine: 305 TBI
Axle/Gears: 3.42 posi
I just bought an '89 rs with a 305 TBI. We have en=missions to worry about here in colo. after you drive it for about a half an hour the check engine light comes on. I ran the codes and came up with a code 32 which is the egr circuit. Anybody ever have this problem and what was the solution? I checked the vacuum lines to the control solenoid and to the egr valve on the intake and they are fine.
Old Sep 19, 2006 | 01:33 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
its a very common problem.
odds are your EGR vavle is bad.
here is something that will help you trouble shoot that code before you spend money on parts.
https://www.thirdgen.org/egrdiagnose
Old Sep 19, 2006 | 08:09 PM
pontiacivan's Avatar
I'm not sure, but doesn't the code 32 check the EGR electronics? I'm not positive the ECM can test the valve itself. I ran a blocked off EGR some years ago but kept the solenoids connected to avoid check engine light. I think a bad valve would actually set one of the MAP codes. Hope this helps.
Old Sep 19, 2006 | 09:41 PM
Damon's Avatar
The ECM has no DIRECT way of knowing whether the EGR valve is functioning properly but it can INFER it from other sensors while running. You almost always get the EGR trouble code after running on the highway, fully warmed up, for several miles. It seems to take steady-state part throttle cruising for a while before the ECM can clue into a malfunctioning EGR system.
I had a very simiar EGR system on my 91 Chevy Blazer and it would do the same thing. You could unplug the valve and it was none the wiser driving around town with regularly changing throttle position- you could drive it for hours like that. But take it out on the highway and cruise at 65 MPH for a while and....... Oops, there's that check engine light again!
Old Sep 19, 2006 | 09:47 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Same thing with my car. I just replaced the EGR valve and all was good.
Old Sep 19, 2006 | 11:16 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
if you dont want to buy a new one you could always take the old one off and clean it using a carburetor or brake cleaner and use a tiny bristle brush of some sort to scrape and get all the carbon out because most of the time the stick in a position.
Old Sep 19, 2006 | 11:19 PM
19RS92's Avatar
Engine: 305 TBI
Awsome thanks for the info guys, thats what I was looking for was simillar stories. It only comes on after highway cruising for a few miles. I'll get the egr changed.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Dwayne614
Sep 28, 2015 08:33 AM
